98 6.5 trouble
Jeffy
Hi I have a 98 Chevy 3500 with the 6.5 diesel in it. I have a problem with it running erratically. Just brush the pedal with your foot and it’s in burn your tires off speed. Idles rough when cold smooths out when warm. I have a pdm relocate on. I’m thinking of replacing the throttle pedal. But not sure if it’s a pcm. Any help greatly appreciated
Jeffy, welcome.
PMD is suspect. But read & learn first:
A low dollar code reader at a minimum should be owned. Dont buy one yet- lets learn more before spending money….
Never just start replacing parts aka firing the parts cannon.
There is no faster way to go broke and create more issues as you do it.
There is one thing that seems to fly in the face of that rule= PMD. The pmd is not a diagnose-able component, so GM said the way to diagnose it is “Replace with Known Good”
So unfortunately for this engine’s ds4 injection pump, you need to own a spare good one just like you would a spare tire.
Best solution for this is on your front bumper where it should be relocated to, you have 2 PMDs on two heat sinks (or one huge heat sink). Get an extra connector and fill the backside either silicone & let cure. Then install it in the spare PMD you have always in place next to the one in use.
Always when you have anything wonky happen with the fueling system- you swap to the known good spare PMD. On occasion the harness extension can fail- especially if it’s a cheap one.
Leroydiesel.com sells lifetime warranty PMD. I suggest start there, getting an extra heat sink if needed, and if you don’t know the quality of the extension harness - his are good.
When you have an old but good pmd, keep it as the backup, drive on lifetime warranty unit until failure then switch to the known good while you ship out the warranty one for its replacement.
In fuel diagnostics there are 2 other items to do.
Clear line on 1/4” return line off the ip (injection pump) and getting a fuel pressure gauge permanently mounted in dash, tapped in metal fitting at the ip inlet after the rubber hose.
99.9% of time I tell people start with those two, but you are most likely a bad pmd.
Do those two after pmd, but before replacing ip.
