Acesneights1
Found A 1997 K1500 Burb wih a blown 6.5. It's an LS, 213k 4x4. Says it's 8 lug although I question that being it's a 1500. He said the valves cracked on # 7 and another cyl same bank . wants 1900$
My biggest question would be "define blown 6.5". Rod shaped hole in block/oil pan or someone that's confused an injector knock with a rod knock? If it's not the custom ventilated block then there may be hope for the engine in it.
It needs heads according to the guy but I wouldn't bother buying heads for a motor with 213k and unknown condition. Better off getting a used runner.
