Wellgeo03
Hello everyone, I am new here and this is my first post. I have a 95 K2500 8 lug and have been looking for at good 4" lift for it. I am looking for a solid bolt on system, preferably one that does not drop the upper control arm, as this truck sees some hard use, and even harder roads.
Also I am not a fan of cutting things up, so if there is one that does not require cutting anything on the truck that would be a huge plus.
My truck is a regular cab 8600 lb GVW model with a one piece rear drive shaft.
Any experience and advice would be awesome!
To give you an idea of the current setup right now, the rear springs have been re-arched, and the T-bars cranked. I have about 6.5" from the top of the tire to the wheel opening in the front and 9" in the rear with 265s. I
t looks pretty bad because the rear is too high, and the CV and tie rod angles are quite extreme, as well I believe I am having alignment issues due to the absolute horrid roads this truck has to endure.
Thanks in advance!
Thanks in advance!
