GM Guy
Manual Trans. 2WD Enthusiast
Hey all,
Dad's 98 has been this way since we got it, and my new 95 is much worse.
Essentially, it is difficult to unlock the ignition. No, not any issue with the steering wheel, but wear in the key, and here you are pushing and pulling and cocking the key just right to get it to rotate. (98, push till it bottoms out, pull slightly while using a finger tip to turn it)
Once you get the key lock happy, it turns freely, glows come on, and it fires right up. Never dies, or anything suggesting ignition switch issues.
So, is this the thankfully cheap 16 dollar ignition lock cylinder going bad, or is this the ignition switch failing?
Also, if it is the ignition lock cylinder, how does it work replacement wise?, do you take the same info needed to get a key cut with you to GM along with the new cylinder, and they code it, you take it home and install, or does it need to be done while installed, therefore requiring a dealer to do the replacement?
Any info appreciated,
Thanks!
Thanks!
