'95 front bearing hubs and ABS sensor > '94????
Big T
Fullerton, CA
Running into the age old problem of frozen bolts on the front bearing hubs. Last time on my '99, I ended up installing another set of steering knuckles, as it was a freaking mess trying to drill them out.
The '94 bearing hubs are different from the '95 as the ABS Sensor and Reluctor wheel are external to the bearing:
attachment.php
attachment.php
attachment.php
The reluctor wheel gets in the way of any effort to get a meaty socket on those bolts.
We have nearly new Timkens bearing hubs with sensors on the '95, but everything is internal to the bearing. Will they work on the '94? The ABS pump is quite different on the '94:
attachment.php
If the '95 hubs will work, do I need to also use the CV axles from the '95? It looks like the reluctor wheel stays with the CV axle on the '94.
If I went with '95 Bearing hubs and sensors, do I also use the CV axles from the '95? Those reluctor wheel look like they're pressed onto the CV axles.
