Big T
The speedometer on the '94 finally broke for the PO just before we bought it. It had been giving him problems for awhile. A couple times on the drive home, it would flip up to speed and then back to zero. 99% of the time it was zero.
So I got a new (used) known to be working gauge cluster from War Wagon here. Got that installed and everything is working but the speedo and the odometer. We pulled and checked the speed sensor on the transmission. The plug and wires to it were in good condition. War Wagon put an ohm meter on it and rubbed a magnet over it. The readings convinced him it was good. I pulled the speed buffer from behind the glove box of the '95 and swapped that in and no go.
Seems like we're running out of things to check. Is there a speed sensor on the transfer case? Any grounds that I should be checking?
