1994 k2500 6.5td
I was doing some research on lift pump relay mods when I got to wondering about the oem fuel pump relay and fuse on the fire wall. Where do these come into play? Correct me if I'm wrong, the oil pressure switch is what directly feeds the lift pump with 12v. So the oem relay and fuse are before the oil pressure switch?
When is that relay powered up and from what? And is that where the ops gets it's 12v from?
Does anyone have wiring diagrams for this for a 1994?
