Quadstar Tuning LLC
Quadstar Tuning LLC
I started this over on DP, but figured I would dabble on TTS too
My build is "Just Because" ... well, because none of it is necessary, but i'm sure I'll have a blast
Here is the checklist:
Potential additional plans pending funds:
I was reading on Leroy's thread the other day that a P400 will fit the 2wd frame..but that's still a dream. At least I can use all of these parts on one someday.
Also, I'm going to be keeping the vacuum pump setup for future boost control/spool valve control ideas with larger turbine housing. I might 'delete' it for now until I need it again though.
Lots of pictures and goPro videos will ensue:
Starting with a 1 BAR (14.5 PSI) actuator for now (you don't see "turbo masters" at the race track):
Here's how the boost control will work for those who aren't familiar with them. It allows you to adjust up from your base spring # that's in the actuator.
- Genuine New Holset WH1C - 12cm turbine
- Custom wastegate actuator. In-Cab adjustable
- PTWiring Solutions HX35 Install Kit
- 97-98 HO water pump Install - To keep current DMAX fan setup
- OPS Relocation
- Water pump restrictor mod. Since I have the dual thermostat x-over already
- Gut upper EGR Intake - Already have VIN F Lower
- Reseal timing cover + new crank seal
- New Timing Set (chain/gears) and Harmonic balancer. Thanks Leroy.
- Swap crossover studs for stainless bolts since one side keeps loosening
- Finish rocker arm retainer mod by doing the driver side
- Flush/Clean the Radiator & top off with new fluids. Add Water Wetter
- Install my EGT gauge
- Put on my spare FFM that I've done a DIY Feed the Beast mod on
- Single tune chip for max fueling
- Replace my old 4" exhaust with a new DE kit. Or just run an open downpipe until September state Inspection
- Head studs
