jpsycoboy5
I have a 94 6.5 with 300,000 miles the problem I'm having is the truck will start up run for a 10 minutes and then bog and die out. I did the obd port trick to turn the lift pump on and bleed air out of the fuel filter housing. I've replaced the lift pump and did the fuel filter I'm at wits end where is the air coming from? I don't even know where to begin please help and let me know what other information you all need to help me figure this out. I keep bleeding the air to get it running so i know it's not air left from filter and lift pump.
