turbovanman
I has boost, :O)
Ok, another bastard child 6.5, it starts but then miss's like its on 6 cylinders, belch's out white smoke, runs rough then after 5 secs smoooth's out and its fine. No smoke while running, lots of power and no blowby. Its a 94 K2500 extended cab long box, auto, turbomaster, Heath chip with longer glow plug duration, home made cold air box, 4 inch exhaust, pmd relocate. Customer brings it in a few months ago, starts rough and pukes out white smoke, I check out all the glow plugs and find a couple bad ones, replace them all, problem solved for now, or so we thought. He bought it back a few weeks ago, its worse, so I spend a few days unplugging one glow plug at a time trying to determine which cylinder, well that didn't work, :mad2:
So I pull out the injectors looking for a bad one, he put these in 1.5 years ago and aprox 20K on them. I find no wet injectors or wet cylinders and for shits and giggles, I cycle the glow plugs, look down the injector hole and they all light up. So on a hunch, I send the injectors out to get tested-good hunch, they are very bad-some the spray pattern is like half, pressures are all over the map AND the nozzles are done, turned blue??? Ok, so put the rebuilt injectors in and son of a bitch, it still does it, :mad2::mad2::mad2: SOOOOOOOO, to me, looks like something went thru IE bad fuel or water and damaged the injectors so I think the IP is damaged? I haven't done a compression test yet but I doubt that's the problem and it doesn't use a drop of coolant. TIA.
