GM Guy
Manual Trans. 2WD Enthusiast
Hey guys, I figure while the driveline is out, might as well drop the t-case and change the front seal so I quit pumping tranny oil into the t-case.
first, any tips for dropping the t-case? it looks a little tight.
other than the front seal, is there anything I need to check out/ adjust/ replace while its out? any things I need to watch out when changing the seal?
I will be leaving the rear seal in, as its the second design (according to Rock Auto) with the big lip and it is sealing just fine, and is easily replaced if it does leak.
thanks!
thanks!
