RonRock
Hi guys, Recently found the forum. Looks like a lot of very good info here so I plan to be around a bit longer.
But I'll start with my first post. It may not go over very well with the guys that have been here longer, but I did "do a search" before this. My search terms were probably not the best, but I tried.
So here goes.
My LP went bad so I replaced it with a new one. Of course the lines were rusty especially where they go through the rubber block that comes off the frame forward of the pump. Well the pump went in OK, luckily the threads were somewhat clean from the previous pump replacement a couple years ago. So things looked good. No leaks, truck runs good life is great!
My first drive and when I get home I see the drip. The return line is leaking at the rust in the line with the rubber (plastic) block. So I need the truck now. Can I cut the rubber hose in front of the leak and put in a hose barb? Then as a temporary fix cut the hard line on the other end and use fuel hose between the two?
Also what is the suggested fuel line fix for the actual repair? I see that Leroy has fittings and hose. I like that idea. Is that a good permanent replacement? It would take time for shipping and as I said I need the truck. Is there off the shelf parts that I can cobble up to replace my line with hose?
Thanks, sorry for the fuel line question. I'm sure it has been discussed before. I got 8 pages back in the forum looking. But I am easily distracted. I kept finding so much information on these 6.5's that I just kept reading, but not finding much on fuel lines.
So here goes.
