searstractorfan
I got a 93 6.5 and it runs warm towards the hot side....I makes 14psi boost if jumped on HARD, but usually 10 or less....My EGT's run at around 500degrees crusing 55 or 60, and the pump was supossedly turned up but it dont smoke alot...My question is, WHY does the block temp go from about 190 to around 210 when the turbo spools up??? I was pulling about 4,000lbs behind it with the OD off, and it was running a steady 210(maybe a smidge more)....Drove home today no load with OD on and ran steady low block temp UNTIL the turbo spools in......I get more than 2psi boost and it starts running up hot QUICK....Why??? any thoughts? Im thinking bigger down pipe and bigger exhaust?
