Mike K3500
Well, like the title says.... Do any you guys think that 600 lbs is possible from a 6.5 ??
Iirc, limiting factor on the 4L80e is the input shaft itself....
If it wasn't for the 4L80E's OD unit, the DURAFLITE trans would have never had been built as the 4L80E could have done the job.
There ya go.
I did know the 4L80E has been built to handle far more than our trucks make.
I guess I must have had the castrated duramax/4L80e van combo and the drilled input shaft in the back of my mind...
Come on up.
I think I have at least what is needed to produce in excess of 300 rear wheel hp without a "tune" of any sort.. I just want gobs of TQ without going to a Cummins.
