Rodd
Recruit
When I swapped out my FSD a month ago (with # 5) I left the #6 that was in the replacement FSD. Is there anything I need to do or will the trucks computer recognize it indefinitely.
I think the OBD2s recognize it right away, and must have a resistor to work. OBD1s relearn it after 50 starts or when a TDC relearn is initiated and can run without a resistor at all.
were just plain ole "bovine scatology" to quote one of my favorite generals.
Relearn on OBD-II will not take place until ko/ko relearn or scan tool relearn is initiated, it will run on old stored value until that happens, once it gets initated and PCM sees that no resistor is there PCM will set a resistor problem code, and will not start.
So what happens when you pull the battery cables? Will it relearn? (Teach me, I don't have a scanner)
