Lubrication Specialist, LLC.
Direct Replacement Oil Cooler and Oil Line Set For 1995-2000 GM 6.5TD
This kit is designed to replace the OEM oil cooler lines which are notorious for leaking. The oil cooler is also replaced so adapters do not have to be used which further decrease the chance of oil leaks. The lines are 5/8" high temp, high pressure Stainless Steel braided Teflon hoses, with crimped brass fitting to prevent corrosion. Hoses are rated at 500 degrees and 1500psi working pressure with a 6000psi burst pressure. Kit also comes with 45 degree brass fittings for the oil cooler as well as both 3/8" and 5/8" NPT fittings for the block, so there is no more guessing as to which line set you have when you order. Also included are rubber lined clamps and necessary bolts to secure the lines to the OEM bracket on the motor mount and ones for between the motor mount and the cooler. By supporting the lines in this fashion you can be assured the lines will not chafe and break like cable ties will that others use.
This kit my fit earlier models but that will have to be determined by calling us before ordering. The oil cooler is the very same as OEM only with NPT fittings instead of obsolete fittings like the OEM. Also NO cutting is needed to make the cooler fit. Just unbolt the OEM and bolt this back in its place.
We did not take short cuts with this kit, everything is first rate. Way try to save a buck when your engine is on the line.
Don't not be fooled by those selling similar kits that say they are the same, because they are not. We have sold hundreds and know how they should fit and we know what to look for. Also some kits are being sold with extra items ("Gimmicks") that just are not needed by most people.
Kit Includes:
* Pair of Stainless Braided Teflon Hoses
* Direct replacement oil cooler
* Pair of 45 degree brass fittings for the oil cooler
* Pair of 90 degree 3/8" NPT brass fittings for early model blocks
* Pair of 90 degree 5/8" NPT brass fittings for late model block
* Four rubber lined support clamps and bolts
* Introductory kit price is $225
5231 Sugar Hills Dr.
Greenfield, Indiana 46140
Call: 1-888-306-4255
www.lubricationspecialist.com
Kit Includes:
