6.5TD engine stumble & stall & die
dwdiesel
Indiana
- Year: ___1995___
- Truck model and class (ie: c2500) __2500_______
- Automatic or Standard _____AT_____
- Mileage: (indicate miles or km) ___260,000______
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) _____IP______
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? _____F, turbo, no EGR_________
- Ambient outside temp: (indicate *C or *F) _____any_____
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ______#2___
- What fuel additives are you using? ____Standyne_______
- Where are you located? _______IN______
- Air filter ____-20K_____
- Fuel filter _____-20K____
- CDR Valve? ____?_____
- Coolant – last flushed/replaced at ____-60K_________
- Oil – synthetic/regular, changed at__synth @ 8K_______
- Batteries – state of charge, (matched set) replaced at _____-30K_______
- Battery cables and grounds (removed, cleaned and tightened): ___very good___________
- Glow Plugs - how many miles on them? ___100K______ What type? ______AC_______
- Injectors - last changed at _____?__________
- What were you doing when it happened? __Installed pro Rebuilt pump, normal driving____________
- How was the truck running fine before this problem appeared? __always seems to have very slight surging or nonsteady run (I don't know to describe, it is so slight that you wouldn't know it unless it was your truck, the engine power doesn't seem rock solid like my 1993 with a mech IP, this one feels uneven like slightly erratic)___________
- Has this problem ever happened before? _____This is the 3rd pump and has <2K miles. The 2nd pump had more pronounce erratic run and a couple of deaths before the PMD died and I replaced with a remote kit from Gomer's. It then ran another 20K and had a few stumbles and stops at the end of its life. Then came the 3rd IP.__________________
- Describe any related factors that might be part of the problem. __The dying mostly was during quick excelleration but not always, on this 3rd pump it stopped after hitting a large pothole on the interstate but started again on its own after 1 second, same night at steady speed 50mph smooth road died again for 2 seconds and restarted on own, about 5 miles later flat quit and wouldn't restart until about 1-2 hours later poking around under the hood but I didn't do anything. Started back up, cancelled the wrecker and drove home and seemed to run as good as it ever had.____________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __Y__ And? __Codes sometimes don't make sense such as EGR codes (I don't have EGR) and set/coast switch. Had APP code 2x last pump but always checks out fine. Past codes w/ previous IPs included codes for the IP, but as of now I just have a DTC 44 (EGR) and DTC 71 (cruise control) and wasn't using cruise and don't have an EGR and according to the VIN never did.______
Diagnostics:
1] Starting:
1a] Does the engine start? _____Y____
1b] Does the engine crank over? ___Y_____
1c] Are your batteries fully charged? ___Y______
1d] Have you removed, cleaned, and tightened all battery connections? ___Y_____
1e] Does your Wait to Start light come on for a time? How long? __wiorking fine_______
1f] Does your glow plug light come on? __working fine_______ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? ____N____
1h] Does the Service Engine Light Glow during Start/bulb check? ___Y_____
2a] Can you hear your lift pump working? ___Y_________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ____Y_____
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ____Y_______
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) ___remote________
3b] Condition of Extension harness (if used) Vendor or Homemade? ___new cond______
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. ____good_____
3d] PMD Make: ____D-Tech_______
3e] PMD Age: _____<1 year_______
4] Stalling Issues
4a] Do you experience stalling only when hot? _____N_______
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) _Y, but also during steady speed_____
4c] Does pouring cool water over the IP seem to help with restarting? __remote mtg, can't check_______
4d] Is stalling momentary (engine recovers)? __Y but getting worse_______
4e] Does SES light come on when engine hiccups? _?_____
4f] Does cruise control quit working when engine hiccups? ____?_______
4g] Does re-starting seem to reset engine, restoring cruise and power? __it restarts on own, or last run after 1-2 hours_______
4h] Changes to dash lights or instruments during stalling events? __normal_________
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? __?_____
5b] Any bubbles or oil film in coolant overflow tank? ___?____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? ___N_______
5d] Excessive white smoke from exhaust on cold start? ____N_____
5e] Excessive black smoke from exhaust under hard acceleration? ____N______
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? ___N________
6b] Maximum boost under load? __?__________
6c] Have you added a performance PCM (reflash) or Chip? _____N_________
6d] Have you changed exhaust / downpipe / crossover? _____<___________
6e] Wastegate – mechanical or vacuum (OEM)? ____vac__________
7a] Single or dual thermostats? ____________
7b] Have you replaced them lately? Manufacturer of replacements? _________
7c] Have you pulled and cleaned Radiator and coolers lately? ____________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ________
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________
__Haven't run since restart and drive home (don't trust it). Although it seemed to run as good as it ever did, and I couldn't be sure if it had any unsteadiness even though I was really looking for it. I took the PMD (newest style) off rebuilt pump to use as a spare but haven't tried it yet. I'm not 100% sure if with the original pump the engine had the slight unsteadiness to it, but I believe the 2nd and 3rd does. The best example is by comparing it to my 1993 6.5TD with mech IP which feels rock steady and this 1995 maybe never did._______________________________
__________________
really sounds like a fuel supply issue. I'd check it out really good. Also put a clear tube on the return line coming off the IP to check for air in the system.
Where did you remote your PMD to?
Being a 95, make sure you tested the LP real good when running. Sometimes the OPS is the culprit and you don't know it till the IP give up.
Also, since it is a 95, may want to do the LP/OPS relay mod to increase OPS reliability.
Another possibilities may be a plugged tank sock.
Check all the grounds, cable connectors, etc. just to eliminate that issue. TurbineDoc have a nice write up on all the grounds location.
You have EGR codes reporting? Have you checked if the Vin is actually an F, or just going by equipment? Has PCM been replaced with wrong EPROM in it?
Pull out the PCM from behind glove compartment and pop open the access panel and check what the 4 letter EPROM code is. You dont even have to unplug it, just pull it back towards you and wiggle it out.
Otherwise you have a ground gremlin. And it sounds like a ground gremlin, like a broken one. check the back of engine on the passenger side. there should be two in plain site, one on an intake bolt and one behind intake on coolant block off plate. Then another on the back of the head closer towards the fuel filter.
