Blueburby1
It'll be interesting if I get much response here, but I'm still licking my wounds on the other site so I figured I'd give it a shot.
So I've got a recurring P1656 Wastegate control circuit error. I replaced the solenoid, and the problem didn't go away, The connector didn't look burned or anything, and the wires don't feel crinkly. Also the turbo seems to function correctly once underway, not a ton of black smoke, plenty of whistle, but no gauge so can't confirm anything. if I get moving and clear the code it stays away, tends to be an intermittent issue at start up/within 5 minutes of start up from cold.
theres a P0236 comes with it, but thats to be expected, the solenoid isn't firing at start up so it makes sense.
Any ideas? hoping it's not a computer fault...and can't spend much time working at it due to current injuries.
