kgw51gmc
I just bought (last week) 1997 Chevy 3500, 4x2, 5 speed, flatbed with 259K miles. Truck looks GREAT, frame is good, test drove it and not much power but sounds good/runs good etc. Drove it 70 miles home at 70MPH. Ran fine. Filled 'er up with fuel and found the tank has a leak in it at about 2/3 full. The guy I bought it from claimed, "truck needs nothing, good truck", and then when I found leak in tank "I didn't know about that..." He also said he owned it 2 yrs, but the title shows (i just noticed) 1 yr of ownership.
SO, drove it 70 miles home and parked it with a leaking tank. Plan to replace tank. Okay. We'll then I figured out non of the cab lights and rear running lights work (probably a ground), and prev. owner said he didn't know that either.
Went to drive it to our farm from the house the other day and it started right up like normal, ran it 1/4 mile and it quit. Shut off, dead in water. No noises, no smoke, ran perfect, then quit.
Towed it home with tacoma. Next morning, FIRED right up, PERFECT. Ran perfect for 4 minutes then shut off, and then would not even try to fire. Batteries good, crank-crank-crank.....no running.
ONE time per day it will start and die within 4-5 minutes............and then will NOT start back.
Accurate diesel website said to pour cold water on the Pump Driver Module to cool it off and try to restart, didn't work. Everyone blames PMD.
I can hear lift pump working. Took fuel filter off near firewall and watched it fill up with fuel from lift pump after I drained with the brass t-handle at front of engine. I ran engine with T-handle open too a few times.
It acts like the key is shutting off, no sputtering, no anything wrong, just turns off..........
Could PMD have been rigged to make it home when I bought it last week, only to die within 24 hrs????? The seller was a cheat/liar, but how could this drive around 70 miles and then be dead the next day?
Lift pump works, I ran it iwth fuel cap off (My chainsaw once stalled within 5 minutes and it was fuel cap so........), has 2/3 tank fo fuel in it. Glow plugs work great, started up in cold the other day.
ANY IDEAS!? :mad2:
ANY IDEAS!? :mad2:
