pitsingerk
I was at another site, and after a couple days, I got no help. I was told this was the sight to use, I'm getting desperate here. Here is what I posted on the other site
I've read through many older posts and I see problems common to mine but not exactly what it's doing. Keep in mind that I'm not new to diesels (15 year ford guy), just new to the 6.5L. Truck is 1997 3/4 ton Suburban. Here are the issues
1. truck starts hard when cold, sometimes starting then imediately stalling, but starts right back up again. One instance it took 8-9 tries to get it going. Checked glow plugs, seem ok, still need to check controler. Truck starts fine when hot
2. truck shudders at approx. 50mph, sort of like it's running out of fuel. Also shudders if hitting excessive bumps/potholes
3. when removing the gas cap, I get a giant rush of air. I've looked under the truck before taking off the cap and the filler hose is almost sucked flat. (will replace cap with vented cap, previous owner had replaced with a locking cap)
4. I was told that the fuel shutoff solenoid needed replaced by the previous owner, not sure if I trust his info. Explained pouring water on solenoid to start truck.
5. Cruise control worked on Saturday when I picked it up, but now doesn’t???
6. After going through the check list, I’m leaning towards the PMD.
Below is the check list filled out.
1. Does the engine crank, or 'turn over'? yes
1a. Does the engine start and run?
yes, when warm, starts/stalls/starts/stalls when cold
1b. Do you have a Wait To Start Light & the amount of time (seconds) lit. yes 8-10 seconds
1c. Ambient Condition (temperature outside indicate F or C) ____75°f
1d. Engine Cranking speed (if you have an accurate tachometer). 0??
1e. Are you experiencing stalling? yes
1f. If Stalling, describe (upon startup only, down the road, hit a bump etc) upon cold start, down the road,
1g. If Stalling, do you notice loss of dash or instruments? no, but will watch closer next time
-note if experiencing stalling,you must indicate PMD location in #24.
1h. Check turbo inlet and air filter for obstructions. Cone filters have lost disk and stopped air to turbo. clear
1i. In a no-hot start, pour a bottle of room-temp water on the injection pump. Does it start now? I was told this is why I need a new fuel shutoff solenoid, but this has not happed to me yet.
1.1 Lift pump test - describe results got fuel out of hose and filter cap
2. Service Engine Light while running?- on/off/intermittent never seen it
2a. Service Engine light does glow during start/cranking/bulb check: Yes/No yes
3. Model year 1997
3a. Odometer reading (indicate if in miles or km) 223k miles
3b. Miles on major engine components if been replaced (example Injection pump)
I was told pump and injectors replace, not sure of mileage
3c. Indicate the model number on the Injection pump (starts DS4 or DB2......)
Can not see a number, not sure where to look
4. Have you scanned for engine codes? (varies by pre/post 96) yes/no no
5. List exact results on engine codes:
6. Air Filter condition (visual check) new
7. Fuel filter condition (freshly changed/condition unknown/mileage since changed) new within last 4-500 miles
8. Condition of Battery terminal connections (removed, cleaned and tightened) cleaned
8a. Known condition and age of the batteries. One battery looks new, other older
8b. Are batteries of differing age or are they a matched set? Not matched, one older
8c. Condition of Major Grounds. (same drill as batt - removed, cleaned, retightened) removed and cleaned what I could find, had to replace ground to frame, it was broken
9. Upon cold start, does the radiator hose get hard quickly? Yes/no no
10. Upon cold start, do you have excessive white smoke? Yes/no no
11. Do you have excessive cranking time before the engine starts? yes when cold
12. Have you used the block heater, and does this effect engine starting?(only try for starting problems) have not
13. During hard acceleration, do you have excessive black smoke? Yes/no some, not excessive
14. Do you have any unusual exhaust smoke issues? no
15. Turbo check out - pass/fail seem fine
16. Do you have an EGR on the engine? (An F or an S engine code 8th VIN digit) F
17. Indicate if you know if it’s a 1500, 2500, 2500HD, 3500, 3500HD. 2500
18. Indicate fuel that you are using: Bio-diesel, #2 Diesel, #1Diesel, SVO/WVO, other Standard fuel from gas stations
18a. If running a VO (Veggie Oil fuel) setup, indicate details of your conversion (homemade, or packaged system) n/a
19. Are you using any fuel additives? If so, please list. no
20. Please indicate geographic region you are in: (example: Texas or Canada) Ohio
21. Do you have any service history available that might pertain to the problem you are having? Not really,
22. Please indicate any modifications to the vehicle that might help us diagnose better. Pmd relocated to inner fender
23. Upon unscrewing the fuel cap, do you have a large vacuum formed in the tank? yes/no yes
24. Location of PMD/FSD? On the pump/remoted over intake/remoted out of engine bay (please specify placement specifically) relocated to inner fender
24a. If remote mounted, describe wiring harness (homemade or purchased from a vendor?) looks professional, not positive
24b. Indicate the location and condition of the FSD/IP grounding wire. Not sure were to look.
25. Are ALL glow plugs in proper working order as per this thread? yes
3. Model year 1997
