Buffalospiritgathering
- Messages
- 10
- Reaction score
- 17
Hey everyone! I've been on this site before but I messed up my account information! ahahah
I've got a 2000 6.5 turbo diesel, 5 window school bus that I've mostly finished... (mostly?)
I've been given a REALLY sick job offer in Kentucky and I've got to get over there soon with my bus, so I have to finish it, cheap and quick.
I'm an alright mechanic, but I have no training.
What I did:
Upgraded the PMC.
Upgraded Lift Pump & Relay
New Alternator, Starter and Flex Plate
and this is how i learned to upgrade my grounds.
It's got a center mount turbo, (GM6, I believe).
(and that's just the motor... the bus itself is a mobile, full solar powered tool shed with a wood stove, a fridge and a bed and the bus is made from all recycled materials and ethical animal products (I like to hunt))
What I need to do, still:
So there are 4 main things that I need to accomplish this:
1) Champion Radiator Upgrade, Re-do every radiator hose line & hope that my heater core still works
2) Water Pump & Clutch Fan Upgrade
3) Delete vacuum pump, manual wastegate with tap & dye set.
4) Possibly upgrade to 4" exhaust to reduce EGTs
There's definitely a small vacuum leak in the vacuum pump area. I'm pretty damn sure the turbo is pulling absolutely no boost because it sucks awfully on hills and even with the doghouse off, I see nothing happening...
I have a few questions for seasoned 6.5 mechanics....
1) I had read that the van type layouts have some difficulty with removing the vacuum pump on the Heath Diesel website. Can anyone attest to this? Why is this? Would it be easier to disable it somehow and just do the manual wastegate with a vacuum gauge install? Isn't it just another wheel run off the crankshaft with some vac lines? The previous owner diefinitely removed the vac lines and plugged that one hole on the pump there...
2) My A/C condenser is absolutely destroyed. I'm grateful that it spins freely in the belt setup, but i think it may be good to remove it entirely if i do the water pump, because it has to come off anyway from what i see on writeups and is TOTALLY ****ed. (Long story....). Could I do this WITHOUT a dummy pulley? I hadn't been able to find a decent one and the one i bought was not correct. Could I just get a shorter belt like the vacuum pump? Do the trick with the piece of string around the belt pattern and see how long it is and buy that? I'd have to see how it physically fits and i don't want to open it up til I have all the parts.
3) The Heater core lines were chopped by a guy who was a friend of a friend who claimed to be a military mechanic but was really a ****ing crackhead. I haven't attached the radiator lines because they're ****ing plugged with screws and it has been mostly sitting, being run regularly while my life took other turns. Could I just run new hoses from the radiator and will they still run straight through the heater core and come out the other side? It's just like a mini radiator, right? I can't afford to replace it, right now.
4) Would an exhaust upgrade help with the bus's overheating issue? I KNOW I have to do the water pump upgrade and the fan and radiator. That's a give-in. would the exhaust diameter make a big difference? I'm not a huge fan of straight piping it because it's damn loud and I want to be inconspicuous.
5) What do I do with the CDR valve? There's a big hole where the CDR valve used to be and it's kinda dirty!
Any other advice you all have for me? The motor runs ****ing GREAT and the blowy is minimal at 145k, even with the tiny vacuum leak.
What I did:
Upgraded the PMC.
