hookedup50
My fuel sock is finally plugging up on highway runs. FPG usually at 8# on highway and truck skips as soon as it dips under 5#. Anyway, I already got the metrum fuel guage, walbro and filter set up from Leroy. My back went south and never installed as the truck wasnt broken or showing symptoms of plugged sock. I knew it was coming though. To the point, while I am working in this area and the tank is 16 years old and I'm finding lots of crap in the FFM, should I get a new tank. Or will the Leroy filter setup be sufficient to run the truck till spring when my back is hopefully better after surgury. My usuall practice would be to get new one and be done with it. My plan unless persuaded otherwise is to move bed out of way for access to sender. Weld mount bracket for walbro and spin on filter adaptor. Then weld new cab corner on extended lower cab(main reason for removing bed cause need access). Thanks in advance. Money is kind of an issue here as well as I'm hardly working.
