6.5 chevy diesel
tino777
binghamton ny
Just got a new liftpump put in. I drove home looked under driver side door area and there was a small puddle of fuel . could this have happened when they put the lift pump in...still leaking today...help
Yeah. The lift pump is under the driver door. You might want to either take it back to them or check and make sure the flare nuts are tight at the lift pump.
Tell them to make sure the orings are installed. If not it will leak no matter how tight the nut is.
