Chevypoor
Active Member
Pulled the intake, IP, accessories and cylinder heads off the truck. These are the numbers off the block: back drivers side bellhousing 2552929, passenger side bellhousing 1625. The drivers side valve cover has a raised GM logo and spec card. I assumed it was a reman block but when I measured the bore she miked at 4.045 or so. What have I got? Is this the bored over original block? I thought 93 was the last year of the 929 blocks. The valley has 929 cast in dots. The cylinder heads have a GM stamp and have a casting number of 13225. Any help figuring out what block and cylinder heads I have and what year they are would be appreciated.
On another note I found a severely bent pushrod, the worst I have seen. Both valve and head appear to be fine. What causes this? Reman defect? Previous owner stated she had a miss and blew white smoke... he thought it was a head gasket.
