chrisk1500
- Messages
- 875
- Reaction score
- 0
I know - wrong section....this one gets a lot more traffic though...
84 Chev 1500 w/6.2 diesel (C code)
The truck will start and idle for about 1 second and then die. If I hold the pedal to the floor while starting it, it will run and stay running at WOT until I let up on the pedal. If I let off just a touch, the engine will die.
Getting 12 volts to the pink wire on the IP....battery connections are clean and tight, same with grounds....
I replaced the mechanical lift pump with an electric pump. Lots of fuel out of the filter bleed.
What's the problem guys? New IP time? I just got this truck to use as a farm beater....don't want to sink big $$$ into it....
Thanks
PS - mods can move this if it absolutely is not allowed to stay in the 6.5 section....
Thanks
