schiker
I get fuel for my 2 tractors in 5 gallon plastic Blitz jugs. I buy fuel from either 2 different truck stops and buy regular fuel instead of offroad since it gets more traffic.
I usually keep a few jugs stored for when I need it. I always add some Power Service biocide, some seafoam, and a cleaner cetane improver (varies either Power service, Stanadyne, Redline etc.) then seal the top and store in garage. Usually burn fuel within a month or so. Note I add to every jug that comes home if its going into the tractor immediately or not.
I refilled the jugs the other day and was adding my usual stuff and since it was real sunny I looked in top since the plastic is a bit translucent and dadgum I see some crud in bottom. Not sure if it was from fill up or had built up some. Wish I would have looked before I filled. I try to take a peek inside at the pump but for some reason did not. Crap ola I am very disappointed to see this stuff. Not sure how it grew.
Anyway here is a picture of I guess is a bit of algae. Its about 4.5 gallons of fuel so I dosed extra heavy with biocide about 2 oz and shook it up a bit and will burn it in either my shop heater or '72 tractor. There is no telling what is in that old tractors tank. I guess I'll shake it occasionally and let the biocide work for a while before using it too.
So what to do when Blitz jug is empty? I guess I'll rinse it out with a bit of gas. Add a quart of gas and shake repeat twice. Probably throw gas out at recycle place. Just have to remember to take funnel and waste jug next trip to filling station. Probably should rinse all my jugs periodically. Some I have painted yellow so not as translucent and can't see in them as good.
What do ya'll do for "jug maitenace / storage" ? By the way might want to try and peek into yours.
