packratt
Active Member
When I get the new engine installed I'll need to do a couple quick oil changes. After the first 3000 or so I plan to install the bypass system so the adaptor will no longer be necessary.
Is it possible to use a stock oil filter installed vertically, like in a 2 wheel drive, if the front drive shaft is removed? I don't have anything requiring 4x4 planned for the next month or so.
