Sunshine
Northern Lights
Hi... could someone tell me the proper method to bleed the brakes with a ABS system...thanks for your help....
/Paul
/Paul
Have someone pump the pedal a few times and hold it down while someone else opens the bleeder. repeat until you don't get any air..
Yep, with a Tech-2 Scanner. Sorry, couldn't resist, but had the same problem, so went to a shop (which I trust) and had it done there.
Cu,
Sven
2
That doesn't work because air will get in as fluid comes out of bleederCan one not open all bleeders and just let er drip till there is no air left in the system?
mityvac handheld bleeder works wonders. and very affordable!
May still be a pocket of air depending where the bleeder screw is, mity vac et als is best way IMO, or 2 guys doing pump & bleed way that has been around forever, can take a LONG time to pump & bleed, if system was totally dry, also if the master cyl went dry, not a bad idea to remove it & bench bleed it.Can one not open all bleeders and just let er drip till there is no air left in the system?
Thanks TD & Kartoon... if i can`t get one here i`ll see if i can get one sent over....
Have a nice summer all & take care....
/Paul
