Hey guys, I checked a ton of threads, and haven't found an answer. I have a 2001 2500hd, 4wd, gas 6.0, 4l80e. I just put a new trans in less than 100 miles ago. Brand new lines, brand new cooler as well. Since day 1, I've had shifting issues. Basically, on first strating and driving, it shifts fine, no issues. As it starts to get warm, it starts shifting super hard, and reving up then slamming into gear. Also, it won't shift into overdrive when warm. I'm running 150-200 average after driving 40 ish miles. Fluid level is good, put in fluid that came with the reman as well. Now, a new problem occurred today. I parked the truck for about an hour, came outside, and trans fluid all over the ground. It was pushing out of the dip stick seal (old seal). I started and ran truck and checked fluid level, waaayyyy over full. Went to limp it a couple blocks home, and no reverse, no drive. But after in gear for a couple seconds, it hooked, and drove and shifted fine the whole way home. Checked level at home, barely on the dip stick, temp at about 110. Any ideas? If there is a thread for this issue, I apologize and please point me to it. Thanks guys.
