Michaeljp86
EVIL GENIUS
I left for school one cold morning and the trans wouldn't shift, 35mph was about as fast as I could go. Turned around and went home to drive something else. Old rusty but trusty jimmy to the rescue. :thumbsup:
Checked the dipstick, it was good, checked the fuse, it was blown. I replaced it and took it for a long drive and it was shifting good. :skep:
The next day I came across some cellulose insulation machines that were to good of a deal to pass up. I drive 45min one way to pick them up and its driving great. I leave there and its 30mph. :mad2:
I pull off on a side road and the fuse it blown, I change it and when it shifts into 3rd the fuse popped. I changed fuses but still only 2nd gear. I pulled off at a public park and pulled the battery cables off to clear the codes and checked the fuse but it was good. I drove off and it was shifting good, I got out on the main road and 2nd gear only.:cuss:
30mph the whole way home. I stopped at my house I just bought and drop off the machines, pull the cables and put in a new fuse. I go to drive home and pop, 2nd gear only.
The next day I got up under there and around the bell housing between the firewall the outer plastic on the wire loom was brittle and falling apart. It looked like a wire was rubbing. I cut a piece of hose and put it around the wires and so far so good.
I thought Id post this so if anyone has a similar problem they know where to look first.
