durallymax
Active Member
- Messages
- 1,929
- Reaction score
- 2
Finally got around to taking a pic of our 02 hooked to the 32' Tri Flex axle gooseneck loaded down.
There are 34 bales on the trailer and the Gross Combined weight is just under 45,000lbs.
The truck sees this load regularily and the edge is run on setting 3 unless its gets too warm then 2.
The gooseneck ball is 1" back from where it was when it was installed and it sits at a bit of an angle.
The trans is just about shot and the truck has had 3 sets of brakes, and is on its 3rd set of injectors.
The trailer has had 4 sets of brakes. We bought it new in 01.
I think i finally talked my dad into getting some air bags for the rear.
every tire on the trailer has been blown out at least once. Now they are all 14ply tires and haven't had problems yet.
Also, even though the axles are flex axles, weve still broken a couple.
Any other comments or question s just ask.
