Jdbdiesel
My truck is acting weird,
the old owner had a performer intake and marine carb on the truck. Needless to say i put the stock throttle body back on, and now the truck is running pretty rough. It takes forever to start which it never did with the carb. when you hit the brakes. It cuts out the motor, I checked for vacuum leaks and none appeared. if you hook up the map sensor it starts hunting then stalls. also we discovered a fuel leak under the truck on one of the lines. Timing is set at 0, Has new IAC valve.
I am not sure but their doesnt seem to be a ground strap from the engine to the body. however their is one from the block to the battery
i am totally stumped as what can be causing all this
any sugestions or ideas would be great
Jeremey
Jeremey
