30 over head gasket?
Yehoshua
WV
My engine has been bored 30 over. What are my head gasket options? I tried to find a felpro part number but could not. Can I use a standard bore size head gasket? Are the standard bore size gaskets already a little bit larger than the actual cylinder diameter?
Standard bore gasket will be ok. Some room there, and if your pistons are 'in the hole' at TDC a few thousandths like they should be (as per OEM) it'll never become an issue.
Yep, use felpro or victor reinze only. the others all have failing histories. Also You know you can NOT re use you head bolts, right?
Welcome to the forum, btw.
Welcome to TTS, hey guys this was the first customer of mine to buy a set of AMG heads!
Please post some pics of the progress.
