3 1/2" straight pipe exhaust
bison
Near Peace River-Alberta
I finallly got around installing my 3 and half inch exhaust(no muffler) and mandrel bend crossover on my 98.
The crossover fitted perfect but building back from of the downpipe from scratch took a bit of juggling.
I decided to keep the stock down pipe as it has not enough restrictions as i thought it had and it fits better than the 3" mandrel bend
I also wanted to be able to remove the down pipe to get to #6 glowplug so i cut the flange of the soot trap and welded it to the exhaust tubing.
10" pipe,three 45% and one 90% elbows did the trick.
I also took the opportunity to swap the GM 5 turbo for the rebuild #8
It was a breeze getting to the downpipe clamp and turbo bolts with just the airfilter and turbo shield removed,everything done just trough the top.
Ofcourse it helps that i have no longer the AC crap in the way(in the trash heap incl the pump and rad core)
I don't know how people get a 4" in there without rattling against the cab or frame,i had enough trouble getting this one to clear a 1/2" over the mid cross member.
I had to flatten my DE 4" exhaust in 2 places (tranny & carrier bearing cross braces) to gain enough clearance on my 1500. My down pipe also required some influence from the sledge it's still very close & I suspect it touches a tad under heavy acceleration.
Precise bends instead of a hack job is my guess.:rolleyes5::D
JK, looks real good, did you have the tubing kicking around?
AK, I think Kennedy uses 3 1/2"
I took a 1000 km trip today.
That straight pipe sounds sweet,a nice rumble as long as i keep my foot in it but hardly noticeable when cruising.
The GM 8 runs in cruise on the flat 5 lbs at 2000 rpm ,a lb and a half better than the GM 5 at the same rpm.
EGT's stay at 450 degrees,was over 500 before.
Mileage did suffer a bit but the power is definitely up.
I'm happy.
My guess is the drop in mileage is due to operator error.;)
Not realy.i had it on cruise 95% of the time.
I only played a bit with the trottle when on the yellow head in Edmonton,it was fun to hear the sound bounce off the retaining walls :D
I got 17.5 mls to the gallon on this trip,used to be better than 18.
I had it up to 15,depended on the hill grade.
About the same as with the old turbo, altough that one would top out at 18 when it down shifted a gear.
With the GM 8 it doesn't down shift no more,it just keeps pulling.
By the reaction of my wife when i floored it ,when she said.. "WTHF was that!!" after she had climbed back in the front seat. :rof:
I can't believe an old goat like you would pass up on that.;):agreed:
