TurboTahoe
Recruit
- Messages
- 790
- Reaction score
- 6
Hi gang,
I'm thinking that my FSD (remote mounted) may be dying. I've filled out the checklist. What do you guys think?
Thanks,
Rob
6.5 Engine Diagnostic Troubleshooting Checklist
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). Stalls intermittently while running
Demographics: tell us about your truck and your ambient conditions: Mild Fall/Winter Weather. Pacific Northwest. Stock 99 Suburban as seen in sig, except for remote FSD.
- Year: 1999
- Truck model and class (ie: c2500) K2500
- Automatic or Standard: Automatic
- Mileage: (indicate miles or km) 120K miles
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) All stock except the relocated FSD. It has a Kennedy remote wiring harness with an SS Diesel heat sink mounted to the underside of the front bumper.
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? F engine Turbo
- Ambient outside temp: (indicate *C or *F) 40-50 degrees F
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) #2 diesel
- What fuel additives are you using? Gallon of B99 in each tank.
- Where are you located? Pacific NW USA
- Air filter Clean
- Fuel filter Clean. Changed 1000 miles ago
- CDR Valve? Clean, working.
- Coolant – last flushed/replaced at 2 years ago
- Oil – synthetic/regular, changed at: Change every 3000 miles, using Delo400LE 15/40 Diesel-rated with Fram HP4 filter.
- Batteries – state of charge, (matched set) replaced at: New batteries, replaced as a pair exactly 12 months ago.
- Battery cables and grounds (removed, cleaned and tightened): I cleaned and tightened these last year when changing out batteries. All grounds look good.
- Glow Plugs - how many miles on them? I think they are original to the vehicle. What type? Not sure...
- Injectors - last changed at: Never changed.
- What were you doing when it happened? Just started, pulling out of the parking spot. Idling at the stoplight. Moving slowly on the parking lot.
- How was the truck running fine before this problem appeared? YES
- Has this problem ever happened before? NO
- Describe any related factors that might be part of the problem. I'm thinking it might be that the FSD is dying, or the connections are bad. I did take the connectors off, sprayed them with DeoxIt, and reconnected them a couple of times (on both ends). But it's still stalling. Therefore, I think it's the FSD itself.
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) NO And? ________
Diagnostics:
1] Starting:
1a] Does the engine start? YES
1b] Does the engine crank over? YES
1c] Are your batteries fully charged? YES
1d] Have you removed, cleaned, and tightened all battery connections? YES
1e] Does your Wait to Start light come on for a time? How long? WTS comes on normally. Starts normally.
1f] Does your glow plug light come on? N/A For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? Didn't check.
1h] Does the Service Engine Light Glow during Start/bulb check? YES
2a] Can you hear your lift pump working? ____________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) Under the front bumper
3b] Condition of Extension harness (if used) Vendor or Homemade? Kennedy harness
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. Ground looks good.
3d] PMD Make: Stanadyne
3e] PMD Age: 10 years old.
4] Stalling Issues
4a] Do you experience stalling only when hot? No, hot or cold.
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) Usually when idling.
4c] Does pouring cool water over the IP seem to help with restarting? Didn't try that.
4d] Is stalling momentary (engine recovers)? YES. SOmetimes it stumbles, sometimes it dies.
4e] Does SES light come on when engine hiccups? NO
4f] Does cruise control quit working when engine hiccups? Don't know.
4g] Does re-starting seem to reset engine, restoring cruise and power? Yes.
4h] Changes to dash lights or instruments during stalling events? None.
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? _______
5b] Any bubbles or oil film in coolant overflow tank? _______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? __________
5d] Excessive white smoke from exhaust on cold start? _________
5e] Excessive black smoke from exhaust under hard acceleration? __________
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? ___________
6b] Maximum boost under load? ____________
6c] Have you added a performance PCM (reflash) or Chip? ______________
6d] Have you changed exhaust / downpipe / crossover? ________________
6e] Wastegate – mechanical or vacuum (OEM)? ______________
7a] Single or dual thermostats? ____________
7b] Have you replaced them lately? Manufacturer of replacements? _________
7c] Have you pulled and cleaned Radiator and coolers lately? ____________
7d] Have you replaced the fan clutch? Manufacturer of replacement? ________
7e] (winter) Have you tested your antifreeze? Good to what temp? __________
7f] (winter) Are you using a winter grille cover? ___________
_________________________________
Thanks,
Rob
- Year: 1999
- Air filter Clean
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
