duramaxdude
Here is what I would like to do. I want to buy a new set of injectors and turn the pop presure up to 2200PSI. If I do that would that make them pop a bit late due to the higher presure or should it be fine.
You dont have to use larger orifice, the IP pressure goes up to 11000+ psi. It will get out what it metered to put into the cylinder since fuel does not compress. a larger nozzle will help lower peak injection pressures though, however reduce atomization.
