Big T
On my '99 with ATT, Heat Programming and this time with a gutted soot trap and 4" straight pipe welded through it in place of muffler.
They are looking for continuous soot after the initial acceleration puff clears up. Too much puff smoke will coat the sensor and make the test hard to complete as the sensor can't zero.
I would not run around CA without a soot trap or mock up in place. I have seen roadside inspections for emissions there like DUI checkpoints. Maybe they don't do these anymore.
If you don't pass your fuel is too high or you have problems with the injection system etc.
Yes, the ATT can pass emissions even with a high flow 4" working soot trap in place.
actually the soot trap does do a thing. It plugs up over many miles. Nice to know the att does pass. I have an upcoming smog test next November. I wasn't looking 4ward to it. although I don't have heath programming for an att. I have the hp tune.Great!!! I guess it proves that the soot trap does not do a thing.
They just did roadside testing near Sacramento a couple of months ago.
Worst comes to worst, I'd just pull the GM4 turbo and vac pump off my son's '95 and get it passed with that stuff on it, then restore it with the ATT.
No need to go that kind of trouble. Stock tune should get it to pass with the ATT or get a low fuel tune for extra insurance. I can't say if they get midevil about vac hoses matching the diagram on Diesels, but, you could bolt a van can near the ATT and get by... I know they can on gas stuff.
I took my 99 in for the first time this past May and passed. They didn't hook anything up to the exhaust if I remember correctly (He may have but I can't remember). He opened the hood and checked the sticker on the air box and went back to the book 3 or 4 times, He then pressed the accel to the floor and that was it. He didn't even hook up the obd2 to it. I asked him why and he said the air box sticker shows that my 99 truck is obd1 so he didn't have to connect to the trucks computer. I had no vac pump and a heath T/M. The guy said that since it says obd1 all he needs to do is check for the cat/soot trap and check for smoke.
