I have 2 different cam profiles that I'm not going to identify other than they are both 6.x cams, maker isn't important in this thread.
These readings were made on a "cam doctor" so they are accurate.
This is the exact info one should receive with any cam being installed and being able to insure clearances and proper set up... simply a cam card...
This is for discussion as to the differences in spec's and possible differences in performance.
Cam # 1
Intake & Exhaust
lobe center sep = 110.5 cam deg
valve overlap = -30.3 crank deg
Intake
valve opening = -20.7 'BTDC
lobe center = 110.5 'ATDC
valve closure = 19.1 'ABDC
Duration = 178.4 crank deg
max cam lift = .27969" inch
net valve lift = .41953" inch
lobe "area" = 18.05 inch * deg
Exhaust
Valve opening = 31.2 'BBDC
lobe center = 110.5 'BTDC
valve closure = -9.6 'ATDC
Duration = 201.6 crank deg
max cam lift = .28016" inch
net valve lift = .42024" inch
lobe "area" = 20.49 inch * deg
Cam # 2
Intake & Exhaust
lobe center sep = 110.4 cam deg
valve overlap = -29 crank deg
Intake
valve opening = -23.3 'BTDC
lobe center = 110.4 'ATDC
valve closure = 22.7 'ABDC
Duration = 179.4 crank deg
max cam lift = .28" inch
max valve lift = .42" inch
lobe "area" = 18.17 inch * deg
Exhaust
valve opening = 28.3 'BBDC
lobe center = 110.4 'BTDC
valve closure = -5.7 'ATDC
Duration = 202.6 crank deg
max cam lift = .27996" inch
max valve lift = .41994" inch
lobe "area" = 20.59 inch * deg
Alright lets see what you all think about the differences in the 2 grinds ....
Does anyone know enough to be able to SPECULATE on what if any difference either cams would make performance wise... what about 1.6 or 1.7 ratio rockers....
Open to discuss possible pro's & con's of each and possible improvements that could be made.
Cam # 1
Intake & Exhaust
Intake
Exhaust
Cam # 2
Intake & Exhaust
Intake
Exhaust
