TMHark
Had a couple weak glowplugs (seemed to be getting worse) so I did some PM to supposedly make things better. No change after swapping parts
New Bosch Duraterms, new GP controller, polished up all the leads to controller, test light flashes strong at every plug when dash indicator is on.
Still one or two cylinders seem to be getting little or no heat and smoke pretty good for 10-15 seconds when cold. Another one only takes a couples seconds to smooth out
Since it happened before (and now after) swapping parts, with exact same symptoms, I'm kind of stumped
Engine spins nicely and fires (on 5-6 cylinders) quickly, after one "wait to start" cycle. You can actually see the puff of exhaust that coincides with the thump of the cylinder missing.
Anyone know the Duraterm glowpug resistance # (and I'll check it with my ohm meter)? Too much anti-seize??
But since it did the exact same before and after swapping these parts, I'm not sure if that would be the cause
Runs great, smooth, etc, with no lack of power after the 30 seconds of noisy/smokey warmup
Cleaned battery terminals, grounds, and replaced the controller and plugs
