frozennorth
First of all hello and thanks in advance. I'm looking for a place to start. I'm thinking that I should figure out if the lift pump is the starting issue and hoping that the service throttle soon is the RPM issue. Do not want to put a new IP in if i don't have to.
New purchase. PO was not much help. He said he replaced the LP but I need to go through the whole truck anyway.
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). ______________Truck will crank and start but only after an extended cranking time (20 seconds at least). The RPM immediately goes to 2000 RPM and will only come down if the throttle is pressed at which time it will rev to 3500 RPM momentarily and then drops to idle and hunts there from 300 to 700 RPM. The check engine light is on as well as the service throttle soon. New PMD with heat shield installed. ______________
- Year: ___1994___
- Truck model and class (ie: c2500) __2500 _______
- Automatic or Standard ____A______
- Mileage: (indicate miles or km) ___285000K______
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) ____PMD_______
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? ____Turbo__________
- Ambient outside temp: (indicate *C or *F) ____20*C______
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) ____#1_____
- What fuel additives are you using? ____Unknown_______
- Where are you located? ____Southern Alberta_________
- Air filter ____?_____
- Fuel filter ___?______
- CDR Valve? ___?______
- Coolant – last flushed/replaced at _____?________
- Oil – synthetic/regular, changed at _____?______
- Batteries – state of charge, (matched set) replaced at _Newer____________
- Battery cables and grounds (removed, cleaned and tightened): ___Good___________
- Glow Plugs - how many miles on them? ____New_____ What type? ______?_______
- Injectors - last changed at _________?______
- What were you doing when it happened? __?____________
- How was the truck running fine before this problem appeared? _______?______
- Has this problem ever happened before? _________?______________
- Describe any related factors that might be part of the problem. ____?__________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) __Y__ And? ___None_____
Diagnostics:
1] Starting:
1a] Does the engine start? ____Y_____
1b] Does the engine crank over? __Y______
1c] Are your batteries fully charged? ___Y______
1d] Have you removed, cleaned, and tightened all battery connections? ___Y_____
1e] Does your Wait to Start light come on for a time? How long? _________
1f] Does your glow plug light come on? ____Y_____ For how long? ____5 Sec_____
1g] Do you see smoke from the exhaust while cranking? What color? ___Y white very small amount_____
1h] Does the Service Engine Light Glow during Start/bulb check? _____?___
2a] Can you hear your lift pump working? _____N_______
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? ___N______
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? _____?______
2d] Loosen an injector line and crank the engine - does fuel come out? ____?_____
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? _____N______
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) ______Intake_____
3b] Condition of Extension harness (if used) Vendor or Homemade? ___Stock______
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. ____Good_____
3d] PMD Make: _____Stanadyne______
3e] PMD Age: ______New_______
4] Stalling Issues
4a] Do you experience stalling only when hot? _____?_______
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ___?___
4c] Does pouring cool water over the IP seem to help with restarting? _____?____
4d] Is stalling momentary (engine recovers)? _____?____
4e] Does SES light come on when engine hiccups? ___?______
4f] Does cruise control quit working when engine hiccups? ____?_______
4g] Does re-starting seem to reset engine, restoring cruise and power? ____?_____
4h] Changes to dash lights or instruments during stalling events? _____?______
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? __?_____
5b] Any bubbles or oil film in coolant overflow tank? __N_____
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? _____N_____
5d] Excessive white smoke from exhaust on cold start? ____N_____
5e] Excessive black smoke from exhaust under hard acceleration? ___?_______
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? ____N_______
6b] Maximum boost under load? _______?_____
6c] Have you added a performance PCM (reflash) or Chip? _____N_________
6d] Have you changed exhaust / downpipe / crossover? _______N_________
6e] Wastegate – mechanical or vacuum (OEM)? _____V_________
7a] Single or dual thermostats? ______S______
7b] Have you replaced them lately? Manufacturer of replacements? ____N_____
7c] Have you pulled and cleaned Radiator and coolers lately? ____N________
7d] Have you replaced the fan clutch? Manufacturer of replacement? __N______
7e] (winter) Have you tested your antifreeze? Good to what temp? _____N_____
7f] (winter) Are you using a winter grille cover? _____N______
____________New purchase. Cannot seem to get the lift pump to run. Speedometer bounces at 0 when the truck is running. I have not had the truck on the road yet at all. _____________________
- Year: ___1994___
Diagnostics:
1] Starting:
3] PMD / IP Issues
4] Stalling Issues
5] Running Issues
