Did any one do a compression test on an 18-1 motor ? If so what was the psi? I got a compression tester,and want to check my 6.2,and see how much lower it is than 18-1. I guess stock is 400 psi?
I checked the Tahoe compression,325 psi @3 compression strokes,and 350 psi max. This is with the pistons .035 in the hole. It smokes white a lot,and I can't seem to get the timing right. I estimated 18-1 but it seems like it's lower.
