- Staff
- #1
Well I made the plunge and bought me a donor truck to do my DURAMAX/ALLISON swap today. The truck has just shy of 162K miles on it when it was wrecked in the left front. It currently has no radiator or intercooler in it, so I can't run it for long. She has been sitting since SEPTEMBER, but fired right up after putting a battery in her and drove on the trailer under her own power.
Since I'll already have the engine and tranny out doing the swap, what should I do to the engine while it is out? It had injectors done to it at 30K, so these currently have just over 130K on em. I was planning on doing a water pump and head gaskets as well as re-sealing the injector cups while it is apart and a set of glow plugs for good measure. Anything else I should do to it? Would injectors be worth the expense with these still functioning?
I know it will be tight inside it's new engine bay, so I would like to do any major work while it is out. And I am also going to do a SUNCOAST stage III to it while it is out. The engine is currently 100% stock, but I will be using EFILIVE to set it up as a stand-alone unit. I'll only be doing a mild tune to it if anything as a stock DURAMAX is ALOT more than my 6.5 had modded.
