Aaronhoffman
1994 silverado ext. Cab 5.7 auto with aluminum drive shaft. Need a universal joint to fit the 14 bolt rear.
I got one through fisher they will have it tomorrow. They bNapa carries them, I think they call them a bastard joint. I used one in my 02 C1500 but its been 10yrs or so.
Most gm shafts for half tons use a s44, are you sure its a 1330? If it has internal snap rings, its an s44 joint. 1330's use outer snap rings, and have the same dimensions as a 1350 except for smaller diameter caps(it uses 1310 caps, but the larger axial portion of a 1350).
I called AutoZone and Advance They don't carry neapco parts anymore.NEAPCO 2-1153. NAPA, ADVANCE, AUTOZONE, and probably O reillys carry them.
The 448 IS for a 1330 to a 1350. So you either got a misboxxed joint, or you ordered the wrong part. Need to know actual dimensions of what you need to tell you anymore. Otherwise were shooting in the dark for what you need.Anyone have any good info to where I can get a 1330/1350 cheap and fast?
That is a PRECISON 448 or NEAPCO 2-3050. You said you already got a 448 which IS what your asking for. The dimensions you give of the joint you got are for a 1310 to 1350 which is a 348 joint, not a 448.I need a 1330 to 1350.
1 and 1/16 on the one axis.
1 and 3/16 on the other
3 and 5/8 from cap to cap.
The one they gave me was in a box for a 448. 1 and 3/16 on the one axis and 3 and 5/8 cap to cap. The other axis is 1and 1/16 cap and 3 and 1/4 from cap to cap
