SmithvilleD
Active Member
Does anybody have (or know where to find) the specs for checking the G80 clutch packs, etc. from a 14 bolt/10.5?
I'm going thru an '04 14 bolt w/ G80 & disc brakes to put under my '95 K2500. Not a problem to find back-lash & other re-gear/new bearings specs, but I haven't found any G80 specs.
Plan to look over the clutch pack frictions etc., & figure there's probably a clutch pack stack height spec range?
I gather these G80 clutches are intended to run w/o any friction modifier - just gear oil.
