Where's the best play to buy?
My local Ace Hardware didn't have one.
Nobody around here seems to have one.
I had to buy one when i installed my pyro gauge. I picked one up at the local Tru Value hardware store.
Jeff, if you can't get one let me know I can get you one.:beer:
^^^exactly. RUn it in a little. Then test fit the piece your threading in. then tap more if necessary.
And take it slow, they will break. If you hear a creak STOP, and back it out.
Youll also need the special drill bit but theyre hard to find so use a 21/64 or 11/32. 21/64 is a little under, 11/32 is a little over.
All the local hardware stores around here have one. The bit in the pick look slike a pipe thread tap
Special bit?? For the pilot hole or?
I think he is referring to a size R drill bit. It is .339" diameter. (11/32" is 0.34375" and 21/64" is 0.328125")Special bit?? For the pilot hole or?
