HoytBows
Does anybody know if there is any differance between a 07 Dually frame and say a regular short box frame? In other words if found a truck that is a dually and i want to put a regular box on it, will that work??
I know the frames are slightly different in how the cross members are laid out. I know when I was installing my B&W Turnover Ball, there were two different ways to line it up depending on if it was a long or short bed.
Also, it used to be that a Dually rear axle housing was actually narrower that a SRW. So as stated before, if you switch to SRW you may need a spacer to bring it out closer to a stock SRW.
haha, yeah 6.5ft bed. Basically does a dually have a different frame than a standard truck of its same weight class
