I just bought a used 06 Duramax, 2500HD crewcab, about a week ago. Two days ago I found a red switch under the dash that was added by the previous owner (bought it from a dealer so I did not meet them) so I flipped it and the check engine light comes on, but I can't tell if anything else happened. So I crawl under the dash and find that the switch is tied into the wiring harness with a fuse.
I then put a code reader on the truck and there are no codes but I can't clear the check engine light. The next day the light goes out.
So today I do it all again. Flip the switch, check engine light comes on, with the switch flipped I try to read the codes but no codes and can't clear the light, flip the switch back try to read the codes but no codes and can't clear the light.
Anyone have a clue what this switch might be disabling/enabling in the system? I also can find no clues that there was any other aftermarket equipment installed in this truck.
Thank you!
This is also my first diesel...
Thank you!
