RYDNHI4X4
Halt Halt Or I'll Release My Dog
Written by Unit453.
I've gotten a million pm's from people asking how exactly to do this modification. I enjoy helping others out so I'm putting together this thread as a how to. Mind you, this is for an 03 model year on up to 07. The new body style's are different.
Parts needed.
Diodes from Radio Shack. Part #'s 4001, 4002, 4003, or 4004. They're all basically the same and your only issue is going to be the length. They're less than a dollar so its relatively cheap...
Everything runs from the low beam fuse. The low beam fuse has 4 pins, labeled with numbers. Take the 85 pin and run the diode with the bottle cap pointing toward the high beam fuse 85 pin. You have to pull out the fuse and look at the numbers to make sure you're getting the right one.
After running the diode from the low to the high beam 85 pin, you now will be able to retain your low beams with the use of your high beams.
Next, take the second diode and run it from the 85 pin of the low beam fuse and connect it to the 85 leg of the fog light fuse. You can wrap the diode around the leg itself, stick it in the hole or solder it, its up to you. Soldering it obviously is the best option since its going to be a fail safe connection. Once they're connected to the 85 pins, you now will retain your fog lights with the use of your high beams as well.
Or....
You can take the diode and run it from the 85 pin of the high beams and connect it to the 85 pin of the fog lights. Now you'll be able to retain your fog lights, when your low beams are on.
Some people use the DRL's as well. Some people may think that this could overload the circuit. I opted not to use my DRL's because they dont put out much light anyways and I didnt want to fry anything.
As always, if you get lost, pm me and I'll walk you through it over the phone.
Parts needed.
Or....
