02 Duramax engine raddle or ???
Snoman
Northern Wis.
Hi Guys, I had my 02 duramax for a couple months now and seems like there is a (raddle) not a knock or tick when I am sitting in the cab of the truck at about 1500-2000rpms at light acceleration or cruising at those rpms. I poped the hood and can't here anything from the outside but when your in it driving it is there, after the truck warms up it seem to go away but you can still kinda here it then but not 1/2 as bad when the truck is cold. The performance of the truck is the same. Under hard accelleration the raddle gos away. what do you guys think? Thanks for any help
I would say normal.
The Duramax is known for the "typewriter" tick. Mine actually does the same thing. :)
Like jeff said, its probably normal. These engines tend to have some mysterious ticking noises that come from inside the engine, don't worry that light tapping (sounds kinda like a typewriter) is completely normal and is present in most all of the duramax diesels. Some engines may be louder that others it all just depends on the machining tollerances.
My dad has a 2003 duramax and he had a rattle at around 1000-1500 rpm, we popped the hood and he reved it till it made the rattle, it was an exhaust heat shield that had came loose, i tightened it, and no more rattle,
good luck
as stated its the infamous typewriter tick. I posted the TSB on here somewhere.
It has to do with the bearings and the oil film on them, it produces a frequency that resonates through the block as metallic sound. Usuallly happens once the miles get up there and depends on machining tolerances.
When was the last fuel filter change? When mine gets dirty, it seems the IP and injectors sound off even more at around 1200-1500 RPM. A new filter and a quart bottle of PowerService Silver to a tank of fuel clears it up outright.
