GM Guy
Manual Trans. 2WD Enthusiast
Hey all,
Cleaning under the 01 project rig today, and I found a cut wiring harness.
It is a 2 wire harness, and is about the only one linking the trans and the t-case. was this for ABS related and was intentionally cut? pretty high up for it to be accidental.
Front ABS sensor is bad (fiberglass sheath is completely broke off the unit bearing hub assy. :O so I am wondering if they were having screwy brakes and disabled the ABS.
Any info appreciated,
Thanks!
Thanks!
